Multiple sub-vi in subpanel
Is it possible to load multiple clones of sub-vi's in a subpanel? How can I do that? I've tried load a reentrant subvi. But it seems that only one sub-vi can be loaded.
Thank you.
(3,466 Views)
Are you trying to put more than one subvi into a sub-panel at a time? Sub-panels only support one subvi at any one instance.
If you are trying to load one sub-vi into many subpanels, this can be done so long as the subvi is marked as re-entrant and you use the correct option (0x08) in the Open VI Reference function (see https://www.ni.com/docs/en-US/bundle/labview-api-ref/page/functions/open-vi-reference.html )
Thoric (CLA, CLED, CTD and LabVIEW Champion)
(3,459 Views)
Yes, I want to load more than one sub vi in a subpanel. So unfortunate that Labview doesn't have such capability at the moment. Thank you.
(3,442 Views)
Why would you want more than one subVI in a subpanel?
Why not have multiple subpanels with 1 subVI in each?
(3,437 Views)
Actually I want to create a program that allows user to load multiple groups of control (consist of 3 numeric controls) at run-time. I've tried using SetParent() function from user32.dll. It works fine as long as the number of controls loaded at run-time don't exceed main window size. In other words, when I scroll down main-window, sub-vi's don't scroll down.
So I wanna try another approach.
(3,433 Views)
