Multiple versions of NI Distributed System Manager
After several updates of LabVIEW and CVI, on my development PC there are three different versions of NI Distributed System Manager (2010, 2011 SP1 and 2012).
I searched for the uninstall program, but I haven't been able to find it.
How can I uninstall older versions?
The same situation happen on the target PC if, for example, I upgrade an application originally developed with LV 2011 with the new release developed with LV 2012.
Vix
In claris non fit interpretatio
Using LV from 7
Using LW/CVI from 6.0
(3,834 Views)
Sorry for asking again, but could someone give me a way to uninstall the older versions?
Vix
Using LV from 7
(3,801 Views)
Sorry for asking one more time, but could someone give me a way to uninstall the older versions?
Vix
Vix
Using LV from 7
(3,764 Views)
Do you have a windows OS?
If so launch Progams and features and look for "National Instruments Software"
click that and all installed national instruments programs should be in the lists and can be uninstalled from that menu
(3,726 Views)
Do you find NI Distributed System Manager in that list?
Vix
Using LV from 7
(3,714 Views)
DSM may have been installed with LVRT so you might not find it in the uninstall list.  The is no problem having multiple versions on your machine so I would just remove the shortcuts if it bothers you.
(3,673 Views)
