Multiple virtual channels for one physical channel
Hello.
I'm using Labview 8.0 with a NI USB-6211 board and an encoder with Z indexing available. If it possible for me to create more than one virtual channel (CI Freq and CI Cnt Edges) for the same physical counter channel (Dev1/ctr1).
Thank you.
Noel
(2,779 Views)
Hiya Noel,
The short answer is YES. You can setup and configure as many virtual channels as you like, in MAX or LabVIEW.
However, these can not be run simultaneously as they will share resources.
Best wishes
Graham Green
Software Product Marketing
NI | Emerson
(2,761 Views)
