Multiple waveforms from a 2-D array
Andrew,
Its working, amazing...thank you for the help...there is one slight modification needed,
If you run the attached VI, you can see that as you change the value of the "Index", you change the waveform corresponding to that particular channel...
The only problem is, when i switch to a different waveform, it starts form 0 and not the present time...which means, if change from "Index" from 0 to 1 after 10 seconds of the test run, it starts with 0th second for the "Index" 1. So, i dont see the 1st 10 seconds of the waveform for the "Index" calue 1. Is there a way to fix this problem?
Thank you,
Eureka
Message 11 of 11
(386 Views)
