Multiple x-axes on xy graph in lv8.0.1
I have an XY-Graph with two X-axis and 1 Y-axis. In Labview 7.1 under graph properties, I could select for each plot which X-axis it should be plotted against.
When I do this in Labview 8.0.1, although it shows both X-axes, it will only let me select one of them. If I save the vi as 7.1 and open it with lv7.1 it lets me select the axes fine. Is this a bug - is there a fix?
(2,659 Views)
To answer my own question, I can go back to the pre-lv7 way of doint it with property nodes:
However I still don't see why Lv8.0.1 won't let me do it with the graph-properties-plots tab.
(2,646 Views)
Hi Russ,
I get the same problem in 8.0.1 so for that version the only option is to use the property nodes, but it's been resolved in 8.20. I appears to only be a problem with the actual properties dialog box rather than the entire graph.
Sacha Emery
National Instruments (UK)
Message Edited by SachaE on 01-31-2007 10:53 AM
// it takes almost no time to rate an answer Smiley Wink
(2,634 Views)
