Multiplexer device
I have little experience in electronics and I need some advice.
I have an old (about 35 years old) Microvolt Signal Analog Multiplexer IPACO in my lab and I'm trying to control it remotely with LabVIEW. Unfortunately, the manual is very weak, and the drivers I found are on 5.25' floppy disks, so it's impossible to do anything with it. The easiest way is to buy a new one, but I don't know what to look for. I need a new device for which I can easily find a LabVIEW driver that can turn on/off analog channels and reverse the current polarity.
Any advice?
(898 Views)
Hi Falcon,
Any advice?
What about one of those relay driver boards, with 4/8/16 relays?
(860 Views)
Can you provide more information ?
Turn On OFF analog Channels - what do you mean by on-off ? Are you switching them on / off or  start and stop reading analog signals ?
REverse polarity - would simple relay circuit would work ?
(826 Views)
