Multiplication of two arrays in LabView
Howdy guys! Is it possible to multiply two arrays in such a way that the first element of the first array is multiplied by the first element of the second array. Next, the second element of the first array is multiplied by the second element of the second array, etc. If so, how to implement it, having two 1D arrays of the same dimension at hand. Thanks to all in advance)
(1,661 Views)
Accepted by topic author Vladyslav_Savchenko
Just wire the two arrays directly to the two inputs of a multiplication. No need for loops or anything. 😄
Easy! Right?
(1,657 Views)
Absolutely. I really thought that solution should be more difficult. Thank you, altenbach, you saved me again)
(1,647 Views)
