Multisim integrated into Labview
Hi all
I am wondering about something.
I am about to create a circuit with programmable resistors which I am going to control via Labview.
I have already simulated the circuit in Multisim 10.0 and I was wondering if I can integrate the simulation into Labview 8.5 and control it.
In short I want to run a VI which imports voltage signals from Multisim along with being able to change the values of the potentionmeters in the circuit simultaneously!
Is that possible, and if so, how?
If someone can help then THANKS ALOT beforehand;)
(3,186 Views)
Unfortunately you can only export simulation data to Labview as .lvm file and processing the data there(select View>>Grapher>>File>>Save As and then select .lvm under Save As). It's is not possible to "control" Multisim from LV.
Regards.
Dennis Morini
District Sales Manager
National Instruments Denmark
http://www.ni.com/ask
(3,142 Views)
Damn, that is unfortunate.
I can´t imagine that that would be hard to create though, a VI button in Labview connected to for example a potentiometer in Multisim, I´ll cross my fingers for the future.
Thanks for answering though!
(3,135 Views)
