Multitask in Single Button
Hi guys, I am Kinni. I am currectly working with my assignment and I am struggling with my Labview project. May I request help from you guys?
The question is, I am doing a single button to perform different task. To make it simple, the button should perform the task as below:
Click          = LED 1 =T   LED 2 = F     LED 3 = F
Click again = LED 1 =F   LED 2 = T     LED 3 = F
Click again = LED 1 =F   LED 2 = F     LED 3 = T
Click again = LED 1 =T   LED 2 = F     LED 3 = F
Message 1 of 9
(4,802 Views)
Why are you asking this question again, since you received a good answer and have not replied to it on your other thread?
To err is human, but to really foul it up requires a computer.
The optimist believes we are in the best of all possible worlds - the pessimist fears this is true.
Profanity is the one language all programmers know best.
An expert is someone who has made all the possible mistakes.
To learn something about LabVIEW at no extra cost, work the online LabVIEW tutorial(s):
LabVIEW Unit 1 - Getting Started</ a>
Learn to Use LabVIEW with MyDAQ</ a>
Message 2 of 9
(4,785 Views)
Looks like what you really want is a counter.  Each time the button is pressed, increment the counter and pass that new value on to the client.  The client can then convert the number into a boolean array and light the appropriate LEDs.
I recommend storing the counter in a feedback node or a shift register.
Message 3 of 9
(4,778 Views)
Rotate an array?
Jim
Message 4 of 9
(4,766 Views)
I am so sorry about this. He is really helped me out of the question that I have asked. Because I having some problem on it. So I think to find other methods to do it before I can solve the problem. Really sorry.
Message 5 of 9
(4,747 Views)
Yea, this was what I thought at the beginning but I have failed on doing this. The number doesn't increase as I expected after I added a increment.
Message 6 of 9
(4,742 Views)
Hi, thank you for your reply and this is the way people told me before but I couldn't understand how does it work and how to do. 😞
Message 7 of 9
(4,734 Views)
Accepted by topic author KinniHan
This will also get it done.
Message 8 of 9
(4,714 Views)
Thank you so much mate 🙂 this work very well. This can be my second method to do
Message 9 of 9
(4,691 Views)
