Multy Slave read Modbus rtu
Hello!
Please look at this Vi. it is multy slave read. it is work, i have value from heat pump and solar inverter. it is a part of code/register read and write. Any tips for optimization of this Vi?
Thanks!
(375 Views)
Hi black,
  • Get rid of the flat sequence, use wires to enforce dataflow execution!
  • Don't split the Modbus reference, use just one reference wire!
  • No need to close the same reference twice…
  • Cleanup the frontpanel and arrange all those scattered indicators more nicely.
  • Do you really need 6 indicators just to display a timestamp?
  • Cleanup the block diagram to follow the StyleGuide. Straighten wires, subVIs, …
  • Use proper datatypes to avoid unneccessary coercion dots. (Example: HeatPump_temp)
  • Do you really need 10 additional indicators just to build on SerialNumber from 5 U16 registers?
  • Why do you need to duplicate code 5 times for the conversion of U16 to two chars? Use a loop instead of all that duplicated code!
    Example:
(130 Views)
