My 8.5 look-up table is not working in 8.6.
Hi, I recently updated my labview from 8.5 to 8.6, but my model has some lookup tables which is not working in the new version so my model is not working as well.
the proporty of the lookup table in 8.6 does not include preview and it shows an array icon when I point it , and when I do right click, I can see the render window seperately.
would you tell me whats the difference between lookup tables in this two version. besides I could not open my model in the last version;(
Message 1 of 13
(4,076 Views)
Hi Sararahimi,
did you install all needed components?
Mike
Message 2 of 13
(4,057 Views)
if you mean simulatuin and control toolkit, yes
I can put the icon but it is not working. the result is the wrong number when I test it.
Message 3 of 13
(4,056 Views)
Hi Sararahimi,
did you install the toolkit, after installing LV8.6? If not, then you should install the toolkit again, with support for LV8.6.
Hope it helps.
Mike
Message 4 of 13
(4,051 Views)
I did it again, but it is not working.
Message 5 of 13
(4,045 Views)
Sararahimi,
Can you attach your code saved in 8.5?
Chris M
Message 6 of 13
(4,017 Views)
here it is.
thanks
Message 7 of 13
(4,003 Views)
sorry that one was 8.6 and this is for 8.5
Message 8 of 13
(4,001 Views)
Sararahimi,
The 8.5 version of your VI appears to be corrupt, but I recreated it.  The preview window seems to be the same in both versions, so I do not really understand what differences you are seeing.  Can you please attach a screenshot of what you are seeing in 8.6 that is not the same in the property dialog?  Also, please explain in detail what functional differences you see between 8.5 and 8.6.
Chris M
Message 9 of 13
(3,984 Views)
There was a bug in Control Design and Simulation Module 8.6 that inverted the values you would expect on a 2D lookup table.  This was fixed in 8.6.1.  See the bug fix list here for ID 124353.  Is this the problem you are having?
Angela
Product Support Engineer.
Message 10 of 13
(3,973 Views)
