My AT-MIO-16E-2 is acting up lately. I am reading input of ~-6V in all
channels even when the cable to BNC 2090 is disconnected. The V
starts out from 60 and slowly drifts up to -6 V. I ran the diagnostic
online where the device failed the. Could this be the root cause of my
errorneous voltage reading? Is there a solution to this problem?
Digital Lines -- Read/Write Verification
This test verifies the operation of the digital I/O circuitry by
performing line input and output. A Boolean value is written to each
digital line and then read back internally. Both True and False values
are tested. To pass, each value read must matc
h the value written.
Testing Port 0, Line 0: PASS
Testing Port 0, Line 1: Please Wait. . .
FAILURE: Incorrect digital value read internally from Port 0, Line 1,
Expected False, Read True.
Testing Port 0, Line 1: FAIL
Testing Port 0, Line 2: FAIL
Testing Port 0, Line 3: FAIL
Testing Port 0, Line 4: FAIL
Testing Port 0, Line 5: FAIL
Testing Port 0, Line 6: FAIL
Testing Port 0, Line 7: FAIL
FAIL: Device 1 has failed the Read/Write Verification Test
Digital Ports -- Read/Write Verification
performing port input and output. A binary pattern is written to each
digital port and then read back internally. All possible binary
patterns are tested. To pass, each pattern read must match the pattern
written.
Testing Port 0: Please Wait. . .
ort 0, Expected
0, Read 2.
FAILURE: Incorrect digital value read internally from Port 0, Expected
1, Read 3.
4, Read 6.
