My Code Gets Stuck in One Loop
Hey LabVIEWer's,
Sometimes when I try to run code with mulitple loops the code execution gets stuck in just one of the loops leaving the other loops to run once initially but then fail to run again unless I stop the code and restart.  Has anyone had any experience with this?  Does anyone have any advice?
I've attached an image of my code.
Mike
(4,266 Views)
Unfortunately, you don't really show the rest of the code, and it's kind of impossible to debug a picture. What are the termination conditions on the other loop. Is the other loop actually stopping, or is it waiting for something? Did you turn on highlighting to see whether you're stuck inside a subVI? You may have subVI dependencies so that the one loop is calling a subVI that eventually uses a subVI that is called by one of the VIs in the other loop. If you get stuck inside this subVI then the other loop as to wait, unless that subVI is reentrant.
(4,254 Views)
To add to smercurio_fc, if all the loops have the same stop condition, why don't you create a shared variable (such as stop control) and wire it to the stop icon of all of the loops?
(4,237 Views)
Thanks for the help guys.  I still can't figure out what's going on but I moved everything into a new VI and now I'm not having the same problem... so it's fixed I guess.
Thanks again,
Mike
(4,163 Views)
That sounds ... odd. I don't see how doing that would fix the problem. Are you sure you didn't do something else?
(4,145 Views)
Sounds like a race condition that "solved" through a recompile.
Qestit Systems
Certified-LabVIEW-Developer
(4,124 Views)
