My First Nugget - Directory Changed Event
That's correct, .NET is not currently supported on LV Real-Time and the best way to do it would be to write a LV VI that looks for changes in folder contents. This forum post has some pretty good info on how to do that:
http://lavag.org/topic/11154-folder-monitoring-for-file-changes/
Hope this helps!
Rob B
FlexRIO Product Manager
Message 21 of 25
(1,234 Views)
I've seen similar code to this posted before, but one thing I was thinking about that would be useful, is if the user event being generated would return which file I/O type caused the callback to run.  By that I mean was there a file created?  Or was one deleted?  I would do this by creating a seperate callback VI for each I/O type with a constant as part of the User Parameter for each type.  Is there an easier way to know which I/O type occured in the event structure when the user event is generated?
Message 22 of 25
(1,215 Views)
You could always use the "size" data from the "File/Directory Info" vi and determine if it increases in size or decreases, but I don't know of a built-in way to determine that information by file type.
Rob B
Message 23 of 25
(1,185 Views)
I don't think this is the right way of doing things because if the file watcher is setup to be recursive you have a longer time scanning directories to get the file/directory list size.
Message 24 of 25
(1,181 Views)
Today a found a community example to this question: Event based File and Folder Watcher
This solution extracts the information out of 'Event data' of the callback VI.
UliB
Message 25 of 25
(1,102 Views)
