My Scaling VI running slow
Hi All,
I am using a structure similar to the QMH Continuous Acquisiton / Logging (DaqMX) template.
My data getting acquired goes into the display loop via a notifier.
When the data come in, I am scaling the analog ins with the subVI shown below:
The issue is is that this causes "hiccups" in my data being displayed - it is choppy.
Is there a better way to do this?
Adding: this is the display loop showing the scaling subVI:
Message 1 of 36
(1,558 Views)
We can rarely debug images.
What are these orange indicators in the display loop? (Just scalars?)
How big are these waveforms and other data structures?
How often does data "come in"?
Message 2 of 36
(1,529 Views)
If the analog data is acquired using DAQmx, you can use scales to have the DAQmx driver scale the data to engineering units for you.
Doug
Enthusiast for LabVIEW, DAQmx, and Sound and Vibration
Message 3 of 36
(1,501 Views)
Thanks Doug - I hate using max for anything.
i read in scale data from an external file that gets updated.
Message 4 of 36
(1,495 Views)
You don't have to use MAX. You can programmatically create scales.
You could continue sourcing slope and intercept from the same file you use now.
Doug
Message 5 of 36
(1,489 Views)
I will try that!
if that is done, is it still possible to access the raw, unscaled data?
I usually like to record both.
Message 6 of 36
(1,481 Views)
@GOB34 wrote:
I will try that!
You will only have access to the scaled data returned by DAQmx. Rather than record both scaled and unscaled waveforms, I recommend recording scaled waveforms along with sensitivity (slope) and offset.
Doug
Message 7 of 36
(1,462 Views)
Really appreciate the help-
Each of my channels has a different scale factor. It seems really messy and cluttered to have to use this approach for many channels.
Message 8 of 36
(1,451 Views)
Accepted by topic author GOB34
This implementation is better suited for multichannel applications.
and instead of "1X" or "10X" you might consider putting the sensor serial number (or some other identifier) as the scale name.
Doug
Message 9 of 36
(1,438 Views)
My recommendation also follows Doug's. Using DAQmx's scales at the driver level is the best performant, scalable and robust, compared to recreate it yourself.
Santhosh
Soliton Technologies
Message 10 of 36
(1,432 Views)
