My Vi runs perfectly on its own, but when i run it as a sub-vi it hangs, unless i make the front pannel pop up when the sub vi is called. Is there any way to fix this?
have you right click the sub-vi and select SubVI-node setup, and selected Suspend when called? This will halt the subVI. You can also set this in the VI options.
