My application freezes up when I plug in additional USB devices?
Ok, so everything is ok until you actually try to use the devices, correct?
Does the USB scanner emulate a serial device or is it like a keyboard wedge?
If its a serial device, can you scan barcodes into hyperterminal?
If it's a keyboard wedge, can it scan barcodes into notepad?
Mike...
Certified LabVIEW Architect
LabVIEW Champion
Message 11 of 13
(476 Views)
Today we built a new PC and only connected the USB-6009 and ran the executable. So there was no barcode scanner or camera connected to the new PC. The program still froze and quit talking to the device. I did notice the the LabView 2012 is a 32 bit install. Since our operating system is a 64 bit, could this possibly be causing the issues?
Message 12 of 13
(441 Views)
Hi damhunt,
That seems unlikely. LabVIEW 32-bit should be fine on a 64-bit operating system.
Here are some frequently asked questions that provide some insight into the relationship between 32 and 64-bit LabVIEW.
Message 13 of 13
(424 Views)
