My array keeps zeroing out already entered data
I have a vi that takes two values and reads them into an array.  It then uses a shift register to go back and get two more values.  When the vi inserts these two new values into the array, it zeros the original two values, even though I am inserting them at the next two index values.
(3,213 Views)
It would help if you posted your VI, or an image of the code where the problem is occurring.
Message Edited by Matthew Kelton on 12-29-2008 05:44 PM
(3,206 Views)
Matthew,
Thanks for replying.  Believe it or not, I finally solved it last night.  I put the initializing sub vi inside a case structure to read the first two values instead of outside the for loop.  The next pass throught the data used the next case structure with a 'insert array' and everything works fine.  I can't believe it took me so long to solve this one, but it really feels great when you get it on your own.
Ron
(3,171 Views)
You should anyway post your code to be reviewed by some experienced LabVIEW programmer : the way you explain your findings leaves some suspicions on the quality of the solution... 😉
Chilly Charly    (aka CC)
(3,168 Views)
