My code looks normal as it should, but when executing, it does not do the job!
If the program stops, the voltage is <10. What value do you receive?
Message 11 of 16
(852 Views)
0.197872; 0.00561237
The first is voltage in Volts and the second is current in Amperes
Message 12 of 16
(847 Views)
Well ~0.2 is less than 10. Maybe you need a delay somewhere or maybe you need to skip the termination comparison until the voltage is greater than 10 for a few iterations.
Message 13 of 16
(837 Views)
The delay is exactly what I felt needs to be done!
I am re-writing this code and make sure that everything is OK, then include the delay in the code to see if it works or not!
Message 14 of 16
(824 Views)
Most power supplies have a programming response time depending on how much of a change occurs in the voltage level. You can check the specs of the supply and setup your delay based on that value so you don't slow down the VI unnecessarily.  If the response time is 300ms and your program loop executes 10 times within 300ms, you could be getting the same reading everytime which will make your stdev close to zero, causing the loop to exit.
aputman
Message 15 of 16
(801 Views)
I have already checked response time from the power supply which is much faster than the command compilation time. So, the response time could not be the problem.
the probllem is in the implementation of the condition to the code as mentioned before:
1-check te voltage fluctuation to be less than 0.1V
2-divide current by 2 and set it as new current
3-repeat 1 and 2 until the voltage is bellow a certain value
Message 16 of 16
(791 Views)
