My compiled help files was working and now is broken in LabVIEW 2009
I've created a .chm file for distributing an add-on VI Library. In order to get my product certified as "LabVIEW compatible", a help file with pretty good documentation is required. Using the Microsoft Help Workshop, I have created a .chm file that works in LabVIEW 8.5 and 8.6. Once I distribute to LabVIEW 2009, the javascript portions of the help file fail. These functions are:
1) Place on Block diagram
2) Find on Functions Palette
3) Open Example
I have determined that this is due to a variable written in NI glang.chm file. The file internal to the chm file is called "lvversion.js" and contains a variable named "lvversion". The marketing decision to name the product "LabVIEW 2009" has contributed to this problem since this variable is equal to "9.0.0", yet the path is (typically) C:\Program Files\National Instruments\LabVIEW 2009\help
 I originally decompiled NIs glang.chm file to analyze the javascript functions that are required for the above 3 buttons to work.I found that NI hardcodes the URL of the help services in a file called "helpserver.js" to be something like "http://127.0.0.1:3580/National%20Instruments/LabVIEW/LabVIEW {major-version}" where major version is "8.5" rather than "8.5.1"
A call to the function "openProj" would then look something like:
 http://127.0.0.1:3580/National%20Instruments/LabVIEW/LabVIEW 8.5/OpenVIFromHelp?PROJ=myProject.lvproj
NI hardcodes these URL in glang.chm::/helpserver.js, and I would gladly read them directly if Javascript were less crippled. Since that hasn't worked yet, I did a regular expression in javascript to determine the version based on the path of the document. This worked until LabVIEW 2009 where the path is (typically):
but the version in glang.chm::/lvversion is "9.0.0"
Yes, I can workaround that by doing some javascript that says:
if(version == 2009)
            version = "9.0"
        else
            version = version
 However, when 9.0.1 comes out, will it be LabVIEW 2009 still, or LabVIEW 2010? I'd like my javascript code to decoupled from any particular version so I don't have to relase a new version of my toolkit for each LabVIEW major or minor release.
(3,014 Views)
THIS has to be the best post I've read regarding why marketers should stay away from programmers, or vice-versa.
Unfortunately, in all likelihood, the naming scheme will continue
(2,998 Views)
OK I finally worked around this. Here is some javascript code that will look for a file called "lvversion.js" inside the <LabVIEW Directory>\help\glang.chm file. save this as a javascript file named "myjavascript.js"
var path=getPath(); function getPath() { path = unescape(location.pathname); //replace %20 with " ", etc. path = path.replace("@MSITStore:",""); path = path.replace(/\w+.html/,""); //strip off .html file path = path.replace(/\w+.chm::./,""); //strip off .chm file //Write javascript paths to page. Helpserver URL is hardcoded in each LabVIEW version document.writeln("<script src=\"ms-its:" + path + "glang.chm::/lvversion.js\"></"+"script>"); document.writeln("<script src=\"ms-its:" + path + "glang.chm::/helpserver.js\"></"+"script>"); return path; }
Then refer to it in an html document that will be compiled into a .chm file along with the javascript.
<script src="myjavascript.js" type="text/javascript"></script>
Now when you call functions from NI's glang.chm::/helpserver.js file, you won't need to prepend and URL or path information to the function to determine which version of LabVIEW you are in. I tested this on 8.5, 8.6, and 2009 and it now pulls up all my examples properly in all of those versions. The following demnostrates a call to "openProj" which opens a project containing all of my examples from a javascript button in the detailed help .html file that gets compiled into the .chm file:
<p class="Body">Refer to the Read From Mobile Registry VI in the <span class="Monospace">labview\user.lib\mobile_registry\examples\Mobile Registry Examples.lvproj</span> for an example of using the Close Registry Key VI.</p><p class="Body"><a href="javascript&colon;openProj('user.lib%5C%5Cmobile_registry%5C%5Cexamples%5C%5CMobile%20Registry%20Examples.lvproj');"><img src="minibutton.gif" border="0"></a>&nbsp;Open example&nbsp</p>
(2,955 Views)
