My goal is to create a button that the user must hold onto so my while loop can perform. Once the user lets go of this button the function should stop. How can I do this ?
Sort of like a dead mans switch
(2,776 Views)
Hi Mangg,
use a button and set it's switching behaviour to "switch until released".
Then you can use an event structure to detect each value change event and use them to en-/disable your "function"…
General recommendation: Put more text into the message body and less into the thread title!
(2,756 Views)
