My scrollbars disappear when resizing my LabView8.6 Block Diagram window
My design can't be seen in it's entirety within the Block Diagram window so I need to use the vertical and horizontal scrollbars to navigate the design.  The scrollbars disappear if I resize the Block Diagram window past "some point".  If I shrink the window very small, the scrollbars reappear.  Other programs I've generated don't seem to have this problem.  Any suggestions?
(2,813 Views)
Check the scrollbars settings, right click on vertical/horizontal scrollbars and change the settings. If the problem still exists, U can send me ur vi, let me have a look to know the exact problem.
regards
sunil
(2,798 Views)
