My scxi 1102 is not reading in max but other boards are what do i do next?
I have 4 SCXI 1102 cards in a 12 slot chassis. None of the SCXI 1102's are rading when I try to test them in max. They show up in max and the chassis checks out ok. I have 5 other boards in the chassis along with the 1102's and they are working properly. Does anyone have any suggestions/
(2,890 Views)
When you say they show up in max, do you mean in the Devices and interfaces, you see the PCI card, and the SCXI 12 slot module, and then 1102 cards and the other 5 you are talking about, or you just see the 5? They only thing I could suggest,would be check to see if max is refreshing correctly. Did you press the F5 key, just in case to see if they would show up?
(2,890 Views)
Everything shows up all 9 cards but none of the 1102's wiil read correctly.
(2,890 Views)
Okay, if it were me, my next step would be to check the properties of each on for
1: the correct terminal block
2: the correct gain and filter settings for each channel. myself its gain of 1 for standard voltage inputs 0-5, and I use a gain of 100 Thermocouple inputs. I cannot remember what filter settings were but I believe I used somere around 15hz for low noise areas.
Next I would check the virtual channels you created in max. make sure each channel was associated to a correct module with cooresponding gain. If you set a channel up for a 0-5v input or 0-10 you would not want to have the gain set at 100 etc.
If all that doesnt help. I would delete all the channels and modules and restart from scratch. Maybe try taking out all module
s and putting a 1102 in the first slot and trying it out alone.
I hope any of this may help. I really cannot think of much else to check, other than trying new modules, chassis or cable.
(2,890 Views)
