MyRIO 2021 example not run
Hi All,
I have installed the latest version of myRIO toolkit 2021 with LabVIEW 2021SP1.
after that I found myRIO works fine with the Wizard(see figure1).
figure1: myRIO works fine in Wizard.
However, when I try to create my very first myRIO project in LabVIEW and try to run it, I found the main VI in the example missing dependencies(figure2). I didn't add any code in the automatically generated code by LabVIEW, but it just simply doesn't work.
anyone have idea how to address this issue? Thx.
(1,268 Views)
From the Error Message, it appears that the problem is in "Open.vi".  Showing us a picture of the Error Message doesn't provide many clues (except "Something is wrong!", but you already knew that).  If you attach "Open.vi", or, better yet, compress the entire myRIO Project and attach the resulting .ZIP file, then we can take a better look and possibly provide some insights.
Bob Schor
(1,243 Views)
Thank you Bob.
I have addressed the issue by reinstall the myRIO toolkit.
will improve the way of asking question in future.
(1,234 Views)
