MyRIO Motor Adaptor - Encoder Readings
No, if I run motor 3 by itself then theres no count direction or value. The motor still turns but I get no encoder counts.
Yes, I use two Myrio Motor Adaptors.
Message 21 of 27
(839 Views)
And you want to use 2 motors in different ADapters together, right?
Message 22 of 27
(837 Views)
So Motor 1 and Motor 3 on the same Digilent Motor Adapter, Motor 2 and Motor 4 on the other?
Message 23 of 27
(835 Views)
Not sure. That what I stated the problem being when I wrote this post. I think it maybe due to them being connected to the same motor adaptor board.
Message 24 of 27
(816 Views)
Yes, thats right
Message 25 of 27
(832 Views)
There is no problem with your VI, there are no software differences between each motors. You can try contacting Digilent for possible hardware troubleshooting.
Message 26 of 27
(816 Views)
Did you solve your problem?
Message 27 of 27
(805 Views)
