MyRIO RT & FPGA
I have custom FPGA code for a time crytical operation and would like to communicate via SPI on RT target. First problem is that I get timeout warning - so looks like that interrupt does not happen (FPGA part). Second problem is that on probes 13 in 14 there I get error 61206 - "The configured item does not exist.
Open FPGA reference is linked to build specification of FPGA build and set to Run the FPGA VI and on dynamic mode.
What should I try/fix?
All the help is appreciated!
(3,713 Views)
I found out that when I recompile FPGA code that there is no timeout - so interrupt happens as long as I do not abbort application. If I stop it normally and close the reference everything seem to be allright.
But problem with error still remains.
(3,630 Views)
The VIs that are generating the 61206 error, where do they get their FPGA reference from? That error normally indicates you are trying to read from a control/indicator on the FPGA which doesn't exist - did you remove them from the custom bitfile? Do those VIs have an input for an FPGA reference (to your custom bitfile).
(blog)
(3,614 Views)
