MyRIO camera problems with LabVIEW
I am kinda new to LabVIEW, so this may be a easy question. When I try to connect my webcamera through a NI myRIO I can't find the camera in the list of I/O constants (my two internal webcameras appear there). This is a problem in the block diagram, it appears when I search for it in the Vision Assistant. Any help would be great!
(4,193 Views)
Does the camera show up under the myRIO in NI MAX? Do you have the IMAQ drivers installed on your myRIO? Do you have the LabVIEW support for Vision installed for the version of LabVIEW you are using (installation order can be important)?
Can you show us what you have listed under software in NI MAX?
There is some more information available under point 2 here: https://decibel.ni.com/content/docs/DOC-30345
(blog)
(4,179 Views)
Recall that the myRIO is a separate computer running a Real-Time OS.  Any peripheral that you plug into it must be handled by Device Drivers on the myRIO.  There are cameras that can be placed on LabVIEW RT systems -- I've never done it, only handled cameras on PCs (which is the situation you have with your internal Webcams).
Is there any discussion of cameras on RT systems in the Vision Forum?
Bob Schor
(4,157 Views)
What camera are you trying to connect? The myRIO doesn't play well with all cameras for various reasons so it oa good to know what you have.
(4,116 Views)
for first step you should gather enough information about your camera and whether labview support that kind of camera or not
also for good advise there are some example on the labview example part with name of get or grab image from imaqdx try some of this example. if you could connect with your camera your problem is your camera mode and you can use some property node to grab image  also if  your camera is usb camera and you have enough information about the your product you can create your own driver with labview driver wizard to make your own driver to be recognized in Ni max
(4,071 Views)
