MyRio- physical channel
I am using a labview code that I found on National instruments website that gives an impulse voltage for a specified time, and it requires a physical channel, what should the physical channel be when using a MyRio-1900
(2,480 Views)
Hi Habch,
This sounds like some type of voltage output code you have running so you'll want to use an analog output channel specified by 'AOx' where x is a number (AO0, AO1, etc).
The manual below has the pinouts of the device:
myRIO-1900 User Guide and Specifications - National Instruments
http://www.ni.com/pdf/manuals/376047c.pdf
Jiwhan S.
Technical Support Engineer
(2,398 Views)
These images are the code that I found on the forums, so if I plug a coil in the AO0 output of the  myRio, or is there something I should modify, or does it not work with MyRio at all?
(I want to use it for both medium length voltage rise, and a very small (almost impulsive) very small voltage rise (in the range of 100mV)
(2,381 Views)
This is how it used to be for DAQ.mx
(2,358 Views)
