Myrio Reading data from sensors using serial port
Hi all
I'm new to labView.
I am using UM7 orientation sensors and myrio for my project. I was stuck on reading data from sensors through serial ports. The sensor can generate a lot of raw data and I only need some of it. The sensor datasheet and its serial interface software links are attached below.
https://www.pololu.com/file/0J773/UM7_Datasheet_1-3.pdf
https://www.redshiftlabs.com.au/serial-interface-software
I wonder whether it is possible to implement in LabView or I need arduino as an interface to communicate between sensors and myrio.
It will be great helpful if anyone can provide some ideas and related examples.
mike
(3,878 Views)
It is possible to use the myRIO with an RS-232 serial port.  I recommend you do a search for "myRIO serial port".
Bob Schor
(3,859 Views)
