N9342C Spectrum Analyzer
I am currently working on my senior project where I am tasked with automating VSWR measurments on a N9342C Handheld spectrum analyzer. I am entirely new to labview and communicating with instruments using coding in general. I am running into an issue with one of the block functions in my code.When I run the code it passes through the "configure trace type.vi" where I recieve the error:
error code: -1074000000
Agilent N934X Series.lvlib:Error Query.vi<ERR>
Instrument reports:
-113,"Undefined header;:TRAC1:MODE<Err> WRIT;:FORM ASC;"
+0,"No error"
<b>Complete call chain:</b>
Agilent N934X Series.lvlib:Configure Trace Type.vi
Untitled 2.vi
I downloaded the instrument driver where this block came from straight from the keysight website and am basing my current code off of a provided example program.
Attached is an image of my current code, which still needs to be improved to get the desired output.Capture.PNGCapture 3.PNG
(2,377 Views)
Can you post your actual VI rather than a screenshot please.
(2,337 Views)
