.NET Callbacks with flash programming tool
Hi Kim.
Maybe Taju_18 can share his wrapper code for the FlashMagic DLL that would make it a much simpler task to implement the wrapper.
/ Anders
Message 11 of 14
(1,378 Views)
Hi
If the wrapper code is for Flash Magic I would gladly take a look.
Message 12 of 14
(1,367 Views)
@A.Rohde wrote:
Hi Kim.
/ Anders
The general idea behind writing a wrapper can be found on Brian Tyler's old lycangeek blog. Brian provided a link to a page that unfortunately is missing the images for the LabVIEW portion of the code, but there is a ZIP file with the full example.
http://detritus.blogs.com/lycangeek/2006/11/turning_a_vi_in.html
http://msmvps.com/blogs/vandooren/archive/2006/11/16/executing-labview-vis-through-c-style-function-...
Message 13 of 14
(1,359 Views)
Sorry I do not have wrapper DLL for flash magic. If you are not familiar with C# or similar languages then you need someone experienced to write that wrapper dll for you. In case if you start writing your DLL pqost your query here I will surely try to help you.
Message 14 of 14
(1,340 Views)
