.NET DLL function call
Hi, as RolfK wrote, you can use Reflection.
I was dealing with the same problem recently. Look here , there is a solution.
Message 11 of 20
(2,392 Views)
Hi Bublina,
I looked at your solution, and I tried it, and I couldn't get it to work.  Can you attach your vi and dll, so that I can look a bit closer?
Kudos and Accepted as Solution are welcome!
Message 12 of 20
(2,387 Views)
You can download those DLLs here
The PNG in the thread is code snippet, it is runnable.
Post here the DLL and specify which method you are trying to use
Message 13 of 20
(2,381 Views)
Hi Bublina,
What did you create the  constant reference above the To more specified class node?
Message 14 of 20
(2,355 Views)
@yang72211 wrote:
Hi Bublina,
Right click the method input and select create a constant.
Message 15 of 20
(2,351 Views)
I can't get your code to work.  See attached.  By the way, how did you get the typeName?  I think the dll that I download has a different version and possbiilty PublicKeyToken, but I only know how to find the version.  What class did you choose for the reference aboe the to more specified node?
Message 16 of 20
(2,336 Views)
Oh, sorry, it looks like I used there older libraries... Smiley Sad
Download 1.6 build, that should work
You specify the class, as the method or property input. Right click the input and create constant.
I really think you should post the dll and the method you want to use, so I can take a look at it.
Message 17 of 20
(2,331 Views)
Right now, I am just trying to get your example to work.  I have attached the DLL and vi.  Can you see what's wrong with them?
Message 18 of 20
(2,323 Views)
No, the VI runs with no errors.
Message 19 of 20
(2,321 Views)
hmm, I will keep looking at it.  Thanks!
Message 20 of 20
(2,313 Views)
