.NET Interop Assembly with LabVIEW Cluster, not able to pass the cluster to function
I trying to create DLL (.NET Interop Assembly) of VI which has simple cluster and unbundle to get integer.
When calling the function, I am not able to pass the cluster/struct to function, attaching image of the code. Please suggest on how to fix the error.
(1,108 Views)
Accepted by topic author LV_COder
You don't have to declare the struct. It is defined in your exported assembly. See the attached example.
https://tmesystems.net/
(1,082 Views)
Thanks, its working fine now.
(1,037 Views)
