.NET Method
I am using a .NET method that returns "byData System.Byte&" LabVIEW views this as a reference, how do I correctly wire to this and get the correct data returned?
(3,210 Views)
The reason for you to see the data as a reference is because in the case where LabVIEW does not recognizes the data type it shows it as a reference. You can get more info on this in chapter 19 of the LabVIEW users manual.
My knowledge of .NET is not enogh for a workaround, I think you can create some sort or wrapper assembly that converts the data types to the types recognized by LabVIEW.
I hope this helps.
Juan Carlos
N.I.
(3,211 Views)
It also depends on the version of LabVIEW. That particular issue was addressed in later versions, but I honestly can't remember which one specifically.
(3,006 Views)
