.NET Month Calendar control and User Events
I am playing around with creating a user event for the .NET MonthCalendar Control. I would like for the user event to fire when a user selects a day on the Month Calendar control, however, I cant seem to even see a list of user events when I select the Register for Events - User Events pick list.
Am I doing something incorrectly here? This is my first time using the User Events portion of LabVIEW (actually, I am looking to enhance one of my existing programs) and I'd figure I'd play in a VI first.
Message 1 of 9
(6,754 Views)
With .net control you have to register an Event Callback. You can trig a user event from the callback vi or perform the action in the callback vi.
Ben64
Message 2 of 9
(6,720 Views)
Another dumb question. How do I get the DateSelected to trigger an event in my Event Handler (or really, anywhere) so I can place the date into an indicator?
Message 3 of 9
(6,661 Views)
Accepted by topic author Eric1977
You can pass user parameters to the Callback VI. In the attached example I'm passing a string indicator reference. You can expand the Reg Event Callback node to pass more than one user parameter.
Ben64
Message 4 of 9
(6,657 Views)
Ben - Thank you for the help. Learned something too!
Message 5 of 9
(6,647 Views)
....could you kindly post the VIs converted to LV2015? Thanks in advance!!
Message 6 of 9
(5,868 Views)
how can i edit the code for the callback vi? it seems to be running even though it isnt
Message 7 of 9
(5,445 Views)
Huh.... Seems to be a bug with .NET callback in LabVIEW. I had the same behavior, not being able to edit the callback VI after running the top level VI. This is from NI's own example located at "C:\Program Files (x86)\National Instruments\LabVIEW 201x\examples\Connectivity\Dot NET"
Before running "Passing Data to a .NET Event Callback.vi"
During execution.
After hitting stop, the callback VI is uneditable.
LV 2019 32 bit
Message 8 of 9
(5,433 Views)
Message 9 of 9
(5,427 Views)
