.NET Progressbar Text
Hello all,
i am writing a VI for the Progressbar of MS(system.windows.Forms) via .NET in LabVIEW. It seems easy to call a Progressbar with .NET Container, and the Style, Color, Value can be changed as well.
But my problem is : i want to put Text on the Progressbar, it just like "55% has been done", i tried to use the Property "Text", but it doesnt work. A methode called "CreateGraphics", "DrawString" may be work, but how can i deal wtih the Parametere "font" "brush" etc.
You Guys have any Idea?
Thank you for your Help!
Regards
APD
Message 1 of 16
(6,337 Views)
LabVIEW already has a progress bar control built in.
Message 2 of 16
(6,330 Views)
thank you for your reply!
the reason why i dont use the progress bar of LabVIEW is all about the appearance :).
The Progressbar of .NET is cool, and it will be wonderful, wenn a Text can ben added into it.
There is another Progressbar, which can be called via ActiveX.
If you have any experience about this theme, could you please give me some tips.
MeerSchweinchen
Message 3 of 16
(6,323 Views)
Well, I don't really know what your definition of "cool" is.
With respect to doing it with .NET, you need to create a "Font" object and a "Brush" object and a "Format" object, set their properties to what you want, and pass these to the DrawString method.
Message 4 of 16
(6,318 Views)
thank you again.
i have also tried this way before, but unfortunately it doesnt work.
The "brush" cant be defined with Property Node or Methode Node.
I dont have so many experences about C#,
so do you have any Example, that i would like to learn it.
Message 5 of 16
(6,310 Views)
Look for examples using Google or trying looking on Microsoft's website.
Message 6 of 16
(6,301 Views)
I don't understand what you mean by this. You use the constructors for the classes to create an object of that type, and then set the properties for that object, and then pass that object to the DrawString method.
Please attach the VI you have.
Message 7 of 16
(6,300 Views)
i have attached the VI.
I would like to put the Text in the middle of the Progressbar.
Regards.
Message 8 of 16
(6,295 Views)
Hi nyc,
i am looking for Help in NI-Forums after i tried to find some Example with Google and MS-Website.
In addition to this, i have no idea now. Do you have any Idea?
Regards.
Message 9 of 16
(6,292 Views)
@AvalanchePD wrote:
Hi nyc,
Regards.
You don't know how to to do something as simple as Google progressbar .NET ????
http://www.c-sharpcorner.com/uploadfile/mahesh/workingwithprogressbarincsharp11302005045625am/workin...
Message 10 of 16
(6,287 Views)
