.NET assembley Error
Hi all,
I'm upgrading this VI from LV 2011 to Lv 2016 and  i still have only this error any help please
THANKS
(3,073 Views)
Hi all,
THANKS
(3,077 Views)
Looks like there is just an update the the .NET library.  Just save and move on.
(3,055 Views)
As crossrulz said; this is just a message to tell you that LabVIEW is using a newer version of an assembly that is on your machine. In this case, moving from LV2011 to LV2016 has shifted from CLR 2 to using CLR 4 and thus preferring .NET Framework 4+. It is backwards compatible (for virtually all use cases).
(3,036 Views)
