.NET rich textbox background image
How to use the set background image for a rich textbox object?
(6,628 Views)
Accepted by topic author JoVMo
From the MSDN documentation: This property is not relevant to this class.
One possible solution is to use a PictureBox and place it behind the RichTextBox. You'd need to then use a transparent-capable RichTextBox, like this one: http://www.codeproject.com/KB/edit/AlphaBlendedTextControls.aspx
(6,569 Views)
