.NET treeview flickering
I have a .NET treeview on my front panel, and I update it every 100 ms. I use the BeginUpdate() and EndUpdate() methods to speed up the update, but still the control flickers upon update. I have read at MSDN, that there should be a treeview property "DoubleBuffered", but I don't have this property in the property list.
I have LabVIEW 2010 SP1, and .NET 4.0.
...and, I have more .NET versions insalled, I have found them in the registry. How do I know, which version is the active one?
regards
Madottati
(3,069 Views)
a similar issue was mentioned in this forum post and might help you:
http://forums.ni.com/t5/LabVIEW/Flickering-in-Table-Indicator-Displays/td-p/2389430
Fo the installed and used .Net Versions this Microsoft Help Page might help:
http://support2.microsoft.com/kb/315291/en-us
Best wishes
Dennis
Work with NI Hard- and Software for about 15 years now.
Certified LabVIEW Developer & TestStand Developer/Architect
(3,042 Views)
