NI 2206 Touch Panel Questions
I am working with a HMI NI 2206. I currently have a LabVIEW project set up to acquire a data source from a real time system. I’m still working on developing the system but I have a few questions with regards to the capabilities of the HMI. I want to know how to enable the HORM system to instantly boot up the deployed VI instead of manually selecting Run from the Project Explore.
Another thing I would like to know if it’s possible to monitor the VI on the HMI from the developer computer.
(2,545 Views)
Are you going to be running a VI or an executable? If it is an exe then we can just set it to begin at start up, but I'm not sure if that works for the HORM system as well. I will have to look into the HORM settings to see if there is a way we could possibly run a script of some sort to start up the VI. As for your second question, the first thing that comes to mind is using remote front panels. Here is a link to a KB which addresses configuring remote front panels for a real-time target:
http://digital.ni.com/public.nsf/allkb/AB6C6841486E84EA862576C8005A0C26
The related links at the bottom of the article are extremely informative as well. Hope that this helps some, if you have any more questions or need any clarification please just let me know!
dK
(2,501 Views)
