NI 4472
What type of connectors do i need to purchase to connect to the input terminals of the NI-4472
(2,833 Views)
The 4472 uses SMB male connectors (physical section of the specifications sheet).
https://www.ni.com/docs/en-US/bundle/ni-447x-specs/resource/373861d.pdf
(2,829 Views)
Thank you for the prompt response. Do I need to purchase SMB female or SMB male connectors to plug into the input ports.
(2,825 Views)
Since the board uses SMB male the cable(s) would need to be SMB female.
(2,823 Views)
