 Chong_L31
			Chong_L31
			04-17-2019 05:34 PM
Hi everyone,
I'm a beginner of LabView, I installed the NI 488.2 and NI-VISA, but which folder should I put them? Right now, the LabView still can't recognize the GPIB controller. I need some help!
Any solutions would be appreciated!
Bests,
Chong
 Gregory
			Gregory
			04-17-2019 05:45 PM
You should install them to the default locations. You have to install them after installing the LabVIEW development system, otherwise you will not have development support.
 Bob_Schor
			Bob_Schor
			04-17-2019 09:02 PM
If you are a beginner in LabVIEW, you probably shouldn't be installing LabVIEW (without someone who knows what they are doing guiding you).
It doesn't really make sense to say "I installed NI 488.2 and NI VISA" and ask which folder to put them in. The "usual" (meaning "the only correct way I know to install LabVIEW" (and I've probably done at least 100 LabVIEW installations over the last 10 years) is as follows:
If you have already installed LabVIEW and did it some other way, you may need to uninstall it. This can be a little complicated -- best to find your local LabVIEW Guru and ask for assistance.
Bob Schor
