NI 5734: Analog Signal Acquisition Problems
Dear experts,
I am currently working on a image reconstruction project using the 7962R FPGA + NI 5734. I am using Labview 2017 (32 bits). I am good at VERILOG coding but it is actually my first time using Labview FPGA.
Short description:
I use Example (NI 5734 - Getting Started) to test NI 5734, but it doesn't work ideally.
Four photos have listed to show what happened. All input signal are generated by Function Waveform Generator (RIGOL DG4162).
PHOTO ONE:
Input signal is 0.5v, 100kHz sin wave.
Displayed waveform is 1.2v, 100k sin wave, nearly no distortion.
PHOTO TWO:
Input signal is 0.5v, 10kHz sin wave.
Displayed waveform is 0.6v, 10kHz sin wave, nearly no distortion. I noticed the waveform voltage is 50% compared to Photo One
Photo Three:
Input signal is 0.5v, 1kHz sin wave.
Displayed waveform is 0.08v, 1kHz sin wave, and the noise is large. It is worth noting that the waveform voltage is only 7% compared to Photo One.
Photo Four:
Input signal is 0.5v, 100Hz sin wave.
Displayed waveform is a noise-filled sin wave. It's terrible!
The Problem:
Why does this happen: as the frequency decreases, the signal amplitude gradually decays. I am certainly sure the input signal displayed clearly and correctly when it connected to osciloscope.
Is Ni 5734 broken? How can I check it?
Thank you very much!
Tao Zhou
(2,733 Views)
I don't have that example to look at, but I wonder if there is any averaging or filtering going on. Is there an obvious place in the example to set this?
If not, can you set your function generator to output an offset sine wave and see if the offset comes through unattenuated?
(2,704 Views)
This is the
(2,663 Views)
Thank you! I have solved this problem which is because of the wrong coupling method.
(2,632 Views)
Great, thank you for the update!
(2,607 Views)
