NI 6009 DAQmx data adquire
The sample rate and the number of samples together determine how much time will elapse while you are taking the samples. You have the VI set to sample at 1000 samples per second or one sample every millisecond.  20 samples will occur in 20 ms = 0.02 s.  Your time constant is such that it takes about 0.6 s to fully charge the capacitor. So you need to collect about 600 ms of samples WHILE the charging is occurring. You have no means of triggering the data acquisition when the button on your circuit board is pressed, so you need to start sampling before you press the button and collect an unknown number of samples for an unknown amount of time to be sure to capture the effect.
It is not clear what you really want, so we cannot tell you how to do it other than in general terms as above.
Lynn
Message 11 of 20
(1,268 Views)
mm thanks, I really want to take the voltage during 5s
second 0 -> voltage
second 0.2 -> Voltage
second 0.4 -> voltage
second 0.6 -> voltage
second 0.8
second 1
second 1.2
second 1.4
second 1.6
In every second I want the voltage...it's like now but with less samples and I don't want the 00 00 00 00 01 01 01 01 01... I'm very frustrated aboout this ...bff
Maybe in the table...it's necessary a counter or I don't know ...but I want what I said here of this example ... S:
Message 12 of 20
(1,261 Views)
Overlapping posts.
Suppose you collect data at 1000 samples per second for 5 seconds. During that 5 seconds you press the button for about 1 second and then release it. Now you will have data the looks very much like your image.
If you only want the segment from 2.1 s to 2.7 s, you can use Array Subset or Get Waveform Subset.vi. If you want fewer points in that subset, you can use Decimate Array, or Index Array and Quotient & Remainder.  Read the help files for those functions and VIs to get more informationabout how to use them.
Lynn
Message 13 of 20
(1,255 Views)
you want to say something like this?
http://forums.ni.com/t5/LabVIEW/get-waveform-subset-not-able-to-get-desired-result/td-p/1089259
thanks for the help 🙂
Message 14 of 20
(1,253 Views)
But...somthing that I said like this
second 0 -> voltage
second 0.8
second 1
second 1.2
second 1.4
second 1.6
is it possible to do? :S
Message 15 of 20
(1,248 Views)
Take the tutorials as suggested by others. Read the help files.
Lynn
Message 16 of 20
(1,240 Views)
I don't think that it's a good solution because It only works reading 5000 samples and I only want 20....
Message 17 of 20
(1,209 Views)
Change the sample rate.
Lynn
Message 18 of 20
(1,199 Views)
I changed a lot of times and the problem continiue...
bfff I don't know what I hve to do ..
Message 19 of 20
(1,191 Views)
The sample rate is the 1000 constant you have wired to the rate terminal of the DAQmx Timing.vi. That tells the 6009 to take 1000 samples per second.
Lynn
Message 20 of 20
(1,177 Views)
