NI 6132 + RT system on a PC
I want to use PC as a Labview RT target and connect the NI 6132 DAQ. Is  it possible?
Przemek
(2,593 Views)
(2,575 Views)
so the answer is YES? I do not ask how to configure the PC but if the NI 6132 will run on the RT system
(2,559 Views)
Hi Przemmo!
There is no problem using your card in a real-time system; however, you need to select the proper DAQmx driver  from the list below:
http://digital.ni.com/public.nsf/allkb/97D574BB1D1EEC918625708100596848
Good luck with it!
Matyas
(2,539 Views)
