NI 6501
Hi all :
I have problems with NI 6501 Device :
If I run continue test on the device (infinity run ) after much time this error appeared ,,attach see file 1.bmp ,,
I also send you the code to see if I do all will
NOTES : that evey time i activate ecah channel alone  ( I turn it on and off) total 16 channel
(4,270 Views)
Will this help?
(4,261 Views)
I do what they suggest but its doesn't help ..
thanks
(4,244 Views)
Hi Elyan,
              Did you notice this
I upgraded the RAM from 512MB to 2GB and have not seen the error since.
Do you Mean to say even after this the problem persists
(4,232 Views)
Hi :
I have PC with 1GHz RAM ..
Does I need to rise it more
thanks
(4,199 Views)
I will suggest you contact ni support over phone. Will be fixed pretty quickly.
(4,173 Views)
Hello Elyan,
I did had a quick look at your code. It is best to keep DAQmx create channel, DAQmx start task and DAQmx clear task inside the loop. It is best to place thos outside the while loop.
With this in mind it is best to create a task for all the ports you want to write to. Inside the loop set (write true) or reset (write false) to the desired port.
I hope this will help you further.
Martijn
Martijn S
NI Netherlands
(4,167 Views)
