NI 6585 : How to use PFI 0 as data ?
I have a FPGA project to do using the National Instrument PXI-6585. There are two connectors : DDCA and DDCB. I need to use every pin of these connectors, so I would like to use the pin PFI 0 of these connectors. In the datasheet, the pin PFI 0 can be use as clock or as data. But, in LabVIEW, I don't see the pin DDCA/PFI0 and the pin DDCB/PFI0 (I see DDCA/PFI[1:3] and DCCB/PFI[1:3]). Do you have any idea about how to use these pins as data in LabView ?
Thank you,
Florian
Message 1 of 1
(2,923 Views)
