NI 8451-Sensor connection
Hi
In one of our application I have to read the internal register values of the sensors. I am using NI 8451 card.
Pin Details of the sensors are-
  1. SDIO – Serial Port Data Input & Output
  2. XY_LED – Led Control
  3. NRESET – Reset Pin (active low input)
  4. NCS – Chip select (active low input)
  5. VDD5 – Supply voltage
  6. GND – Ground
  7. REG0- Regulator Output
  8. SCLK – Serial Clock Input
My question is NI 8451 is having separate pins for SDO & SDI But sensor is having one pin for SDIO. How to connect them  ,I have to read the register values & some registers are read/writable.??
Please reply as soon as possible, it is very urgent
Regards
R
(4,115 Views)
Maybe the SDIO name has confused the issue. On the 5020 SDIO just means Serial Data Input/Output. The communication protocol used on the 5020 is I2C. So you should be using pin 29 and 30 on the 8451 as the proper connections for I2C to read/write the 5020 registers.
New LV User
(4,098 Views)
R,
I am wrong. The 5020 is indeed SPI. I am sorry.
New LV User
(4,096 Views)
Hi
Thanks for reply.
I am using SPI communication not I2C.And i have to interface 6 sensors (slave devices) with the NI USB 8451 device.
Regards
R
(4,083 Views)
SDIO stands for serial data input output.
(4,076 Views)
