NI 9205 Query Channel Voltage Range from the FPGA?
I think I know the answer, but I wanted to make sure...
Is there a way to programmatically query the voltage range setting of the channels in the NI 9205 from the FPGA?  How about from RT or from a remote host when using the NI 9205 on a chassis in FPGA mode?  I clearly see how to set it but cannot find how to query it.
Thanks!
(2,970 Views)
Is there a particular reason that you need to read the voltage range from the module? If you are setting the range using a Front Panel control, you can read the value from the control.
(2,942 Views)
Yes, there is a particular reason.  So is the answer 'no'?
(2,937 Views)
There is no way to query the specified voltage range of a module in FPGA. You can only set the voltage range.
(2,929 Views)
