NI 9205 fluctuations
Hello There
I am using NI9205. Here I have connected 5 Torque Transducers (TT) of which one is on 12V supply and four are on 24V supply (common to all four). When I start mesurement through the module, the torque value signal varies from 0.001V to 0.01V which is nearly 10-15Nm variation. Though for 12V supply TT i have connected 1 MOhm register (as shown in manual of module) between TT signal output GND to pin-17 common of the card.(not shown in diagram) Which works good. My queries are as follows,
1. Whether the connections I have made are ok? need any improvements.
2.How should I connect other TT?
3. Is there any specific way for receving signal and software filters? Because I am just using DAQ to read signals and some software signal filters to minimize the variation, but it slows the signal reading.
Please help me out
Thank you in advance
Message 1 of 1
(2,453 Views)
